Hyprland DE and Lua
Hey, hey!
With 0.56.0 coming very soon, I’ve updated the dotfiles to now use Lua configs.
What has changed?
For now, nothing. These dotfiles are staged for 0.56.0, so your current 0.55.x ones are unaffected.
What will change?
Once you update to 0.56.0 and update DE, your dotfiles will be moved to lua.
If you had made customizations, added to custom.d, etc, you will need to rewrite those modifications for lua. Old configs will not be loaded.
Everything else (paper, lock, etc.) stays the same.
Cheers!
