Hello world!, I hope this is the correct place to do this.. my name is J.. I am primarily a mycologist by day but i am a tech/programming enthusiast by night. I started my adventure with hyprland about 6 months ago(as well as arch) and ever since then i have been on a fix teaching myself programming and learning as much as i can..(Ive had a rough life until about 5 years ago) i really dont know many folks but i wanted to create something to not only make certain aspects of hyprland easier for the community especially since the recent .Lua migration(which im digging btw)
Anyways, Ive created a visual tools super lightweight tray app that allows you to switch between animations,border size, blur, and more right from the app.. and the best part is its easily expandable.. just drop your new .lua configs in the proper presets folder(comes with an injector if you are comfortable dropping it in the directory directly.) and the list will repopulate instantly!…. Anyways i hope this helps someone out there..
