Hyprland 0.53.1 built from branch v0.53.1 at commit ab1d80f3d6aebd57a0971b53a1993b1c1dfe0b09 clean (version: bump to 0.53.1).
Date: Fri Jan 2 21:20:57 2026
Tag: v0.53.1, commits: 6766
Hyprlang: built against 0.6.7, system has 0.6.8
Version ABI string: ab1d80f3d6aebd57a0971b53a1993b1c1dfe0b09_aq_0.10_hu_0.11_hg_0.5_hc_0.1_hlg_0.6
no f
Hi guys,
long story as short as I can:
I had some conflicts when updating with pacman and after not being able to solve them I consulted with ChatGPT and after running some commands and from what I understood moving fully from the git version to the stable one, that issue was fixed and I was able to run and update normally again.
However now when I try to run hyprpaper, I get this error, and I assume its not a hyprpaper error but a GPU drivers one.
Any help?
after running hyprpaper:
ERR from hyprtoolkit ]: [EGL] Command eglQueryDevicesEXT errored out with EGL_BAD_ALLOC (0x12291): EGL_BAD_ALLOC error: In eglQueryDevicesEXT: Failed to allocate device list.
